please help my frigidaire is leaking from the tub and Ijust need to find out how to replace the seal????
It is a time consuming job, but not too difficult. I would get a friend or relative to help with some of the lifting. This service manual will show you how to do it. Just take your time and it should work out fine. Yours is a fairly common problem with this model, but the repair should take care of it and the parts are not expensive. http://frigidaireservicetips.com/pdfs/488_3.pdf
