sternberger
#1 Posted : Sunday, February 24, 2008 5:26:05 PM(UTC)
sternberger
Anytime the agitator is engaged, there is a clicking noise. The speed of the clicking noise is tide to the rythme & speed of the agitator. The noise seems to be coming from the transmission/clutch. Any ideas on what the problem is and how to fix?
#2 Posted : Monday, February 25, 2008 1:17:00 PM(UTC)
Remove the fabric softener dispenser.
Remove the agitator retention screw.
Remove the agitator and the agitator base (the bottom part of the agitator).
Check the splines inside the agitator base and on top of the transmission shaft.
- The part number for the agitator base is AP246882
- The part number for the transmission is AP3500335
Here are the break down diagrams for the Crosley washer Model CW8000W
