The bottom trim piece holding the glass in the oven door rusted out. I got the repair kit, which includes a bottom piece and two side pieces. Whirlpool redesigned it so you don't use the bottom screws anymore; instead, you fit the "dimples" from the side pieces into the bottom piece. When trying to do this, we can't make it fit. Any advice?
We figured it out! The glass needs to be on the OUTSIDE of the side trim, not on the inside.
I'm glad you were able to fix it.
