kirkb
#1 Posted : Sunday, February 24, 2008 12:02:45 PM(UTC)
kirkb
Whirlpool thin twin stacking w/d how do I open the lower front cabinet to get to the coupling from motor to gear box? Is service manual available?
#2 Posted : Monday, February 25, 2008 12:23:23 PM(UTC)
Remove the three screws holding the access panel (between the dryer and the washer). Tip the panel down and lift it out.
Release the two top retaining clips (instructions #6) and slide the washer top forward off the unit.
Remove the washer front panel retaining screw on each side, remove the front panel brace and remove the front panel.
Follow the instructions on how to replace the motor coupling.
- The part number for the motor coupling is AP3963893
Here are the break down diagrams for the Whirlpool laundry system Model LT7000XVW0
