glovejoy63
#1 Posted : Wednesday, November 11, 2009 6:33:54 AM(UTC)
glovejoy63
My dryer worked fine last night. This morning no heat. is it as simple as ordering a new heater element. Or how do I trouble shoot.
#2 Posted : Thursday, November 12, 2009 5:14:49 AM(UTC)
Rear bulkhead, felt seal & rollers replacement parts for AMANA LEA30AW | AppliancePartsPros.com
Here is a manual
http://www.servicematters.com/m...ary/docs/RS3200005R2.pdf
You should trouble shoot first.
Be sure to mark or make a diagram of where the wires go if there is a possibility that they could fit in two places.
First flip the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heater requires the full 240 volts.
Better yet measure it at the plug with a meter.
L1 to L2 should be 240 volts
L1 to Neutral and L2 to Neutral both should be 120 volts.
Be sure to unplug the unit when working on it, 240 volts is lethal!!!
Check that a wire has not burned off ts the unit's terminal block.
Remove both wires from the heater and measure it, should be around 10 ohms. Then measure from each connector to the case both should be open (infinite ohms). You are checking to be sure you do not have a grounded element which can heat and not be controlled by the thermostats.
Note if the element is broken you can often see this.
Check the Hi-limit thermostat and the thermal fuse on the heater assembly both should be 0 ohms.
Check the operating thermostat on the blower assembly, should be 0 ohms
If the thermal fuse is blown I would also replace the hi-limit unless you have a grounded element.
If the fuse is blown be sure to clean/check your vent system and the blower wheel. Also check that the lint filter is not coated with fabric softener residue.
godie
#3 Posted : Friday, February 26, 2010 7:04:00 AM(UTC)
godie
Denman,
I have an Amana Commercial Quality dryer LEA30AW. It had been making this noise off and on while running that almost sounded like the buzzer wanting to go off. Yesterday it stopped running. The timer has a low click to it and continues to run thru a cycle and then the buzzer sounds, but the dryer doesn't turn on. The only way to stop this is to unplug it. I've read so many things on the internet, my head is spinning. I need to know what part to order so I can fix it. Un-employed so calling a repairman is out of the question.
Here is what I did.
I checked the thermostat and the blue wire was burnt, so I removed the wires and set my multimeter to the continutiy test. IT says if it is below 50ohms, the alarm will sound, which it did. The digital display did not stay at zero, it kinda just jump all over the place.
I also checked the termal fuse on the heating assemble. It has no burnt wires and the continuity test was the same.
So, from your post, are you saying you want 0 Ohms, and if it isn't, it is bad ?
Thanks in Advance
