alanO
#1 Posted : Tuesday, July 2, 2024 8:29:10 PM(UTC)
Guest
Rank: Guest
Groups: Guests
United States
I have an older, but clean GSH25JFXB defroster that runs for too long, or what I thought, too hot - but let me explain:
The problems started 2 years ago when my defrost elements kept burning out.
I purchased the cheaper ones first and they burned out in 3 months.
Then I purchased an OEM defrost element and that burned out in 8 months.
But always after replacing the element, the defrost period was running normally and I had no steamy issues.
4 weeks ago, it blew again. I replaced it again with a cheaper defrost heater and this is where the problems started.
The heater ran for about 20 minutes and the top of the freezer and ice box melted causing water to drip down into the water dispenser. During the cycle, I observe that the defrost element shuts off around the 15-20 minute mark (no glow) and the freezer then sits quietly for another 5 or 10 minutes warm. Then the freezer compressor kicks in, and after about another 5-10 minutes, the evap fan kicks on.
Now, I have gone down a few rabbit holes. I have replaced the controller board twice. I purchased the first one from eBay, and when that didn't work, I purchased a new one from GE.
I also changed both temperature thermistors and the thermostat that is supposed to cut off when it gets too hot. I've measured the voltages on the J1 connector of pin 3 and pin 4 and they are within tolerance and all components fall within tolerance. I more recently replaced the defrost element. I measured ohms across the element between the new one and the old one and there was a slight difference of 3 ohms. The new one was 22ohms and the old cheaper one was 19ohms. And guess what, it still gets too hot and melts the ice.
I'm at a loss and aa about to give up on this, but thought I would try one more reach out to see if someone with more experience than my DIY electrical skills to offer advice. The unit is otherwise in excellent condition and I think buying a new one didn't make sense at the time, but now I almost wish I did. But perhaps there is something else I missed.
Any advice is welcome.
WilliamM/APP Team
#2 Posted : Wednesday, July 3, 2024 5:53:17 AM(UTC)
WilliamM/APP Team
Groups: Moderators, APP Team, Registered
United States
Was thanked: 14 time(s) in 14 post(s)
AlanO, thank you for your question. The evaporator and freezer thermistors WR55X10025 would need to be tested for resistance at multiple temperatures to identify if one might be causing this failure. Each thermistor should measure 36.4K Ohms at 5°F, 21K Ohms at 23°F, and 12.7K Ohms at 41°F. If the thermistors are within this range, it is likely that the main control WR55X10942C is not cutting off the voltage to the defrost heater at the proper temperature.
Aluntus
#3 Posted : Wednesday, July 3, 2024 10:40:16 AM(UTC)
Aluntus
Awesome - I will run another range test on those thermistors and get back to you. Is it possible though that even with the change of board for a new one from GE, it could exhibit the same problem?
applianceaid1
#4 Posted : Wednesday, July 3, 2024 7:37:56 PM(UTC)
applianceaid1
Canada
Was thanked: 10 time(s) in 10 post(s)
Hi all,
Gotta wonder why that safety thermostat is not cycling the heater off before any or sever damage can be done?!
**The heater ran for about 20 minutes**
That doesn't seem long, most defrost cycles are 35-45 minutes long but either a thermostat or the board and thermister shut off the heater and it stays off for the rest of the defrost cycle before the compressor and refrigerator comes back on.
Is the freezer empty? Less food and the temp will increase a lot. At least 1/2 full and the mass of the food will help hold the freezer temp.
Sorry, more questions than answers.
jeff sr.
Appliance Repair Aid
https://www.applianceaid.com/
