Joined: 6/27/2024(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: Texas
Washer fill up water regularly and run at starting after little time and it stop and make noise like chocking humming noise. And won't run. Even there is no clothes in tub. It stop in between start and rinse with chocking noise. What is the issue. How can i troubleshoot the problem and fix the issue. have model Kenmore 800 top load washer.
Joined: 5/12/2024(UTC) Posts: 0 ![Canada Canada](/Content/images/flags/CA.png) Location: Ontario Was thanked: 10 time(s) in 10 post(s)
Hi, ** model Kenmore 800** With the correct info, I hope someone can help. Kenmore 800 is a name and not a model#. https://www.applianceaid.com/model-number.php Some model# helps. Fills - ok. Agitates? Drains? Spins? Makes a weird noise - yes. jeff sr. |
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: TN Was thanked: 14 time(s) in 14 post(s)
Dharmesh8, if the model number of your appliance could be provided as it shows on the model/serial tag, it will allow the most accurate information to be presented.
