BlueWRXPride
#1 Posted : 7 months ago
BlueWRXPride
United States
My fridge is about 10 years old, and for the past few weeks it has been making ice very slowly. The water dispenser has normal flow, and there's a pretty new filter installed. What can I check?
applianceaid1
#2 Posted : 7 months ago
applianceaid1
Canada
Was thanked: 10 time(s) in 10 post(s)
Are the cubes normal size?
Freezer temp should be checked with a thermometer.
jeff sr.
Appliance Repair Aid
https://www.applianceaid.com/
BlueWRXPride
#3 Posted : 7 months ago
BlueWRXPride
United States
Yes the ice cubes seem normal. In this fridge the ice maker isn't in the freezer, it's a separate unit on the ceiling of the main refrigerator area.
applianceaid1
#4 Posted : 7 months ago
applianceaid1
Canada
Take a reading from both.
Freezer and the ice maker room.
jeff sr.
BlueWRXPride
#5 Posted : 7 months ago
BlueWRXPride
United States
The fridge is set to 0 for the freezer and 35 for the main fridge.
I have a laser thermometer and measured the freezer around -2, the fridge at 35, and I opened the little flap in the ice maker and measured between 14 and 19 depending on where I pointed it.
applianceaid1
#6 Posted : 7 months ago
applianceaid1
Canada
**I have a laser thermometer and measured the freezer around -2, the fridge at 35,**
Those seem good....but a simple pocket thermometer often works better for testing a refrigerator.....JMO!
**I opened the little flap in the ice maker and measured between 14 and 19 depending on where I pointed it.**
Not so good.
Ice maker must get below 15ºF before it will even start up.
Fan not working? Duct frozen/frosted over? Refrigerator Icebox Fan Motor should be DC14V.
jeff sr.
applianceaid1
#7 Posted : 7 months ago
applianceaid1
Canada
UserPostedImage
jeff sr.
applianceaid1
#8 Posted : 7 months ago
applianceaid1
Canada
#21 is the ice maker fan linked here.
This is suppose to help remove some of that nice freezer temp air and dump it into the ice maker room.
jeff sr.
