Rank: Guest
Groups: Guests
Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
There is a hose that comes up the outside left side of the dishwasher and then does a 180 into a plastic part. The other side of this plastic part is inside the dishwasher where the water goes into the dishwasher to fill it up. The water sprays out the side of the plastic part thus flooding my floor.
It doesn't seem to be blocked or cracked.
Joined: 5/12/2024(UTC) Posts: 0 Location: Ontario Was thanked: 10 time(s) in 10 post(s)
Hi, Model#? https://www.applianceaid.com/model-number.php Some model# helps. **The water sprays out the side of the plastic part thus flooding my floor.** It does not need to be clogged, but can get calciumed up and the incoming water hits the build up and sprays water down the side of the d/w. We use to remove that hose, carefully run a drill bit down inside the spout entrance to help clean it out. jeff sr. |
