I have a whirlpool washing machine in which I need a 10 blade female connector. The harness is obsolete and so is the motor#34001122 I have seen the same connector still being used. The one I need is specially 10 contacts (only 9 are used) This is a pic of the end on the motor, I need the connector that connects to this. [img]https://share.icloud.com/photos/081jHjZwDIk2j0ruwCPTSXs0A[/img] https://share.icloud.com...81jHjZwDIk2j0ruwCPTSXs0AEdited by user Saturday, June 8, 2024 3:18:50 PM(UTC)
| Reason: Not specified
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0  Location: TN Was thanked: 14 time(s) in 14 post(s)
Mauiman808, unfortunately, the manufacturer does not list the connector end for the motor at all. As this is the case, it would be safe to say the manufacturer did not produce the Molex connector as being available separately from the harness.
Joined: 5/12/2024(UTC) Posts: 0  Location: Ontario Was thanked: 10 time(s) in 10 post(s)
Hi all,
Marr connectors or inline connectors and join the wires together (one at a time) to by pass that connector might be the only repair.
jeff sr. |
