I have a GE Side by Side refrigerator Model GSS25IYNXHFS. The LED lights on the refrigerator side only are dim.
So far, I have replaced the following:
3 LED light boards within the refrigerator side Door switch on the bottom of the refrigerator side Main control board in the rear of the refrigerator
The lights on the freezer side work fine at full brightness, this issue effects only the brightness of the LED lights in the refrigerator side only, all other functions of the refrigerator appear to be working fine.
Any advice would be greatly appreciated!
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0  Location: TN Was thanked: 14 time(s) in 14 post(s)
Jhauter, thank you for your post. If there is not a shorted component in the DC voltage side of the control, this would indicate that there is an issue with the wiring running from the control to the lights. Unfortunately, these wires are not repairable.
