Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I took apart the control panel and the internal metal panel from the door of my Bosch SHVM78Z53N/01 … disconnected all the cables, now I don’t know where I have to connect each of them … I lost the pictures that I took of those connections . If someone have pictures of those connections I really will appreciate the help … just to give an example: I see 2 long yellow cables that are coming out from the red light that can be see on the floor but I don’t know where they have to be connected Edited by user Wednesday, May 8, 2024 9:18:15 PM(UTC)
| Reason: Missing model and brand of dishwasher
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0  Location: TN Was thanked: 14 time(s) in 14 post(s)
Lafred, the 2 yellow wires will connect to connection X2 on the user control. There will be a 7 red wire connector that goes to connection X1, and a 3 orange wire connector that goes to connection X3. There will be 3 red wires that will go from the user control to the dispenser rinse aid sensor. There will also be 2 yellow wires that will go to the dispenser actuator.
