Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Hello, I would be grateful for any help with this issue:
My Frigidaire oven heats but there is a strong smell of gas. The igniter and burner light just fine, and I tested the safety valve for continuity and it works, so not sure what the issue is.
I notice the air shutter on the baking arm is open pretty wide but I don't think I've ever changed it so I'm not sure if that is relevant.
Thank you! Raphael
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0  Location: TN Was thanked: 14 time(s) in 14 post(s)
Does the oven burner have yellow flames when it is lit, and is the gas smell there if the oven has been off for a bit? Also, if the model number of your appliance could be provided, it will allow the most accurate information to be presented.
