ltompsen
#1 Posted : Friday, February 22, 2008 7:30:13 AM(UTC)
ltompsen
My refridgerator is leaking water under the crisper trays and we have checked the hose. What else should we be looking for?
:confused:
roycreamer
#2 Posted : Friday, February 22, 2008 5:37:06 PM(UTC)
roycreamer
Groups: Expert
if it's a top freezer model, depending how old it is, there is a sort of cup in the very top of the back of the refrigerator section. it is hidden sometimes underneath some plastic parts on the top of the refrig. if you have a plastic tube running down the back of the outside of the unit, this little cup is probably your problem. run it under some hot water and, tada, no more leak.
this is only applicable on older models...
hope this helps...
roy
kathyz723@aol.com
#3 Posted : Thursday, August 7, 2008 7:24:15 AM(UTC)
kathyz723@aol.com
I also cleaned out the 'trap' on the back of the fridge. It was filled with gunk. Works fine now, no water under crisper drawers or under fridge.
