The Dryer won't heat. A Tech looked at it and said the Fuse Box was bad. Is there a way to identify this. and if so how.
Thank You Scott
Yes, if you are talking about the house wiring. It can be measured at the machines plug with a meter. L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral both should be 120 volts. |
THIS FORUM IS DEAD!!!!!!! |
