Rank: Guest
Groups: Guests
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Kenmore 500 auto moisture sensing cutting off after 10 min no matter what setting airdrop moisture or timed heating element coming on and cutting off like supposed too everything seems to be working right everything cleaned inside and out including motor. Model# 110.65132411 any help or test I can do on motor or board?
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0  Location: TN Was thanked: 14 time(s) in 14 post(s)
As soon as the dryer stops, the push-to-start switch would need to be tested for 120VAC at the light blue wire going to the motor to the white wire at the timer terminal S. If there is voltage, the timer is sending voltage out properly and the motor would be the cause of failure. If there is not voltage, the light blue wire at the timer would need to be tested for 120VAC to the white wire at the timer. If there is not voltage here, the timer would be the cause of failure. This is based on the unit being thoroughly clean all throughout the cabin.
