Guest
#1 Posted : Saturday, April 20, 2024 5:54:26 AM(UTC)
Guest
Rank: Guest
United States
Hi, my water, ice maker, lights, middle drawer touch pad are not working. Have replaced the water input valve from where the water enters the refrigerator. Have replaced the water filter. Have taken apart and tested the water dispenser switch for continuity. Have replaced both door closer switches.
Was watching a video and caught repair person saying if the doors are not reading closed, the water will not initiate. The service code RC door switch input Code 16 and FC door switch input code 17 for checking if the doors are open and/or closed always read open code1. It does not change for both refrigerator and freezer.
Any Thoughts?
Thanks,
WilliamM/APP Team
#2 Posted : Saturday, April 20, 2024 1:04:17 PM(UTC)
WilliamM/APP Team
Groups: Moderators, APP Team, Registered
United States
Was thanked: 14 time(s) in 14 post(s)
Based on the information provided, if there is not a warp in the liner of the doors or cabin, the main control would be the cause of failure if the door switches have continuity when tested from the main control W10843055.
