Rank: Guest
Groups: Guests
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Hello! My Whirlpool dryer model WED4815EW1 has begun stopping mid cycle for 10-15 minutes and then starts again on its own. I cleaned out the lint trap as well as the vent hose to outside. There was almost nothing in either, so I don’t think it is clogged. It is 1 year old. What else can I check?
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0  Location: TN Was thanked: 14 time(s) in 14 post(s)
Thaddeusgardner, when the dryer has shut down, is there 120VAC on the outgoing light blue wire of the push-to-start switch? Also, does the drum rotate smoothly?
