Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
hi! model: PODC302J/05 i have thermador double wall oven. the problem is it will work if i turn on both units at the same time, but it will not if one of them on "speed conv". for example i put upper (or lower doesnt matter) for "speed conv" (or bake) and then lower to "bake" (or "speed conv") the lower (or upper) light will just blink but no heat. blinks constantly (no error). doesnt matter upper or lower first, or what i set up, the second unit will just flash and no heat. if i put both units on "bake" and "broil" or just "conv bake" it will work. even if "true conv" upper and "conv bake" lower it will work. the "speed conv" works and the fan works too. on the both units. but only if not at the same time my email - freetleu@gmail.comthanks! Edited by user Tuesday, April 9, 2024 12:08:31 AM(UTC)
| Reason: update
