Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
The new replacement motor came in and has only one of the two Spade connectors for the two blue pulley tensioner switch wires How do I determine where to plug the other blue wire in? On the old motor, there was a second spade connector next to the main/black hot feed... On the new motor there's no second Spade connector on that front terminal, only one for the factory installed black feed.. Trying to determine where to connect the second tensioner pulley switch wire. Any ideas, try to find a wiring diagram for that motor, so far. cannot..
Rank: Guest
You should list make and the model and s/n of this unit in order to provide help
Rank: Guest
