Joined: 3/17/2024(UTC) Posts: 0 Location: Mississippi
I need a little help with a control circuit board model number. I have a GE stove model #JBP78GS1 that needs a new control circuit board. The board that I need is discontinued by the manufacturer so I am looking for a used one. I came across one on e-bay but not sure it would work for my stove. My stove's control board part number is WB27X5524 and the model number is 164D2851P006. The one I found was the same part number as mine but the model number is slightly different, 164D2851P016.My question is, will this work for my stove? Any feedback would be helpful. Thanks, John
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0 Location: TN Was thanked: 14 time(s) in 14 post(s)
John4321, unfortunately, we would only be able to recommend what the manufacturer has specified for your model. As there are many program variations from control to control, using an alternative part not listed as an approved substitute may not work properly with your appliance.
