AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Bosch Dishwasher Display Goes Out After Latching Door
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I replaced my builder grade dishwasher with a one year old Bosch SHP878ZD5N which I purchased from a friend. It worked perfectly but the wife wanted all the appliances to match so the dishwasher was sold. I have two issues. The display goes out when the door is latched. There’s a flashing red light at the bottom right of the door. What’s up?
Groups: Moderators, APP Team, Registered Joined: 4/11/2019(UTC) Posts: 0  Was thanked: 1 time(s) in 1 post(s)
Hello, The flashing red light is probably indicating that the door switch is not reading the door is shut. Pull the unit out a bit and hold a magnet over the left screw of the door switch. If the unit starts to run the door switch is ok and just needs adjusting. I remember having to place some washers under the screws to get these to align.
Dishwasher Repair
