Groups ready for retrieval: Registered
https://youtube.com/shor...vXBs?si=lEuKqU--HW60rFIs]Issue video Hello, My Samsung dishwasher has drainage issues at the beginning of the cycle. When I start it, and it’s full of water, it will sometimes try to drain for a long time without success. It will then display an OC code. The first time it happened, it even leaked on the floor. When I drain it using a shop vac, I can restart it and it will complete the cycle. Please see the video through the link posted at the beginning of the post. Thank you very much, Edited by user Saturday, March 9, 2024 11:23:03 AM(UTC)
| Reason: Not specified
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0 Location: TN Was thanked: 14 time(s) in 14 post(s)
Marc1984, in regards to the drain, it would be recommended that the drain hose and sump are inspected for any clogs. If there are no clogs, the drain pump can be tested for incoming voltage during a drain cycle and if there is voltage, the drain pump has failed. In regards to the water at the beginning, if it is clear it is an indicator that the water inlet valve is leaking by and will need to be replaced.
