Guest
#1 Posted : Saturday, February 24, 2024 12:38:19 PM(UTC)
Guest
Rank: Guest
Groups:
United States
The water reservoir is freezing which causes the water dispenser to stop working. This is a recurring problem. The reservoir also appears to be leaking.
brad l/APP Team
#2 Posted : Tuesday, February 27, 2024 10:28:09 AM(UTC)
brad l/APP Team
Groups: Moderators, APP Team, Registered
United States
The reservoir freezing can be caused by the refrigerator temperature being set too cold, or an issue with the airflow in and around the reservoir. The leak is from the reservoir freezing and cracking. In this case, the reservoir would need to be replaced.
Edited by user Tuesday, February 27, 2024 10:28:43 AM(UTC)  | Reason: Not specified
