Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
There is a spring under the star keeping the igniter in but I can’t remove the spring to replace the igniter.
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0  Location: TN Was thanked: 14 time(s) in 14 post(s)
There should be a clip under the spring that would need to be removed to allow the spring to drop down. Once both are removed, the electrode should be able to pull free.
