Good evening all. My dish washer arms don’t spray. The tub is full of water and it drains at the end of cycle but the arms don’t spray. I swear I hear the circulation pump running. I removed it and check ohms and my reading is .556m ohms. Is that bad? What is the spec for it? Does anybody know? Thanks.
Groups: Moderators, APP Team, Registered Joined: 2/26/2024(UTC) Posts: 0  Location: Cleveland Tn
Ray,
The resistance that you are getting will be correct. You will want to check to make sure that there is nothing clogging of the circulation pump and ensure that there is 120 Vac to the circulation pump. If there is 120 Vac to the circulation pump but no operation of the pump then this will be a faulty circulation pump that will need to be replaced.
