AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Kenmore electric dryer typical model 110.68522700
Rank: Guest
Groups: Guests
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
The above dryer model was given to me for possible repair due to a no heat situation. The normal items were checked first including the t-stats and thermal fuse. The next item checked was the heating coil which was found to be an open circuit. The coil assembly typical p/n 3403585 is rated for 5400 watts at 240 volts. The wire was broken at a position adjacent to one of the insulator blocks at a position near the opposite end from the spade connectors. I have seen many of these heater coil assemblies with a broken wire and the break almost always occurs at an insulator block but it also coincides with a distortion of the thin separator plate near this end of the coil assembly. The wire used is a NiChrome alloy of about .060" in diameter and cannot be repaired at least easily. . I am curious to hear from other techs to see if they have noted this wire breakage at this same position and also it they have noted this more frequently on the US produced assemblies as compared to the foreign sourced electric dryers. Any input is appreciated.
Rank:: Member
Groups: Moderators, APP Team, Registered Joined: 4/11/2019(UTC) Posts: 0  Was thanked: 1 time(s) in 1 post(s)
Usually you wouldn't want to repair this element anyway only replace it. [AP3094254] Seen these break in various locations.
Dryer Repair
