Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
When I start my washing machine, the sensing light comes on. The drum will rotate a couple times and then a little water will pour in. And that’s all it does. I ran the diagnostic test on it, and the only code that shows is a blinking sensing light. I replaced the little switch on the bottom of the washing machine but it is still doing it. Does anyone have any suggestions?
