GTD42GASJ3WW GE Dryer stops after 10-15 minutes. It will not restart by pushing the start button. If we let it sit for another 15 minutes or so, we'll hear a soft "Click" and the dryer will restart. We've cleaned the vents, replaced the cycling thermostat, high temp thermostat and door switch. So far the parts were cheap enough that I was ok with just throwing parts at it given the time it takes to take apart. I'm at a point where I'm thinking it might be the motor. Like everyone, we are a very busy family and "some" dryer is better than "no" dryer lol. Anything else anyone can think of before spending $150 or more on a motor?? This dryer is a mix of old and new tech, there’s no dry sensor or other control boards. But, I have a multimeter and tools....any assistance is appreciated. Edited by user Saturday, February 10, 2024 8:12:17 PM(UTC)
| Reason: Not specified
Groups: Moderators, APP Team, Registered Joined: 4/11/2019(UTC) Posts: 0  Was thanked: 1 time(s) in 1 post(s)
Hello, The motor is designed to shut off if it overheats. Make sure lint has not built up around the motor.
