Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
After a bake, turned off the oven and the oven would not turn off. It sounds like it is stuck in convection mode, even though the last bake was not convection. Had to flip the circuit to turn it off. This is the only way we can keep it from turning on when it has electricity. Received error code FIE0 replace oven UI.
What part corresponds to the oven UI for this model (Model: KDRS407VSS04)?
Appreciate the help!
