Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I have a Samsung Dishwasher model DW80M2020US. I have been working through some issues. Originally the motor was leaking and causing the water leak sensor to cut the cycle. Well I guess that had been going on for a while because it corroded out my turbidy sensor. I have a new sensor but I want to know what is the type of electrical connector? I need the female side of connector to connect it back as the damage was to the wires and destroyed the connector. Edited by user Thursday, January 11, 2024 4:44:39 PM(UTC)
| Reason: Change user
