Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I have a GE PSA2201RSS02 that suddenly started taking more time on speedcook recipes. The upper heat and microwave seem to be working fine, but the lower heat seems to not be working at all. The only test I could think of without disassembly was to run it for a bit with the settings at U-0, M-0, C-0, L-10 so I’d be asking the unit only for heat from below. I got ZERO heat from that scenario. It would seem this part might be the cause: https://www.appliancepar...b44x41526-ap7194075.htmlBut is there sine way to test this thing before I begin ordering parts randomly hoping it will work? And how the heck do I get to this part? It seems I may need to remove the whole bottom of the unit to access this part from below. Is that the case? Thanks for your help!
