Guest
#1 Posted : Saturday, December 30, 2023 1:26:59 PM(UTC)
Guest
Rank: Guest
Groups:
United States
Maytag Bravos XL
My laundry room only has cold water available. Washer is getting error code LF. Is there a way to bypass this error without connecting hot water.
Guest
#2 Posted : Saturday, December 30, 2023 1:56:21 PM(UTC)
Guest
Rank: Guest
Groups:
United States
I am not acquainted with this model but my guess is that the washer senses that you are only providing water to the cold side and not making a connection to the hot side connector. You might want to get a splitter hose connector and use that to provide a water connection to the now vacant connection. As an alternative to verify the washer function try switching the hose connector from the cold side to the hot side connection.
