I've bought a second hand Siemens dishwasher and the pump keeps running as soon as switched on. There is no blockage as it is draining. There is no water in the well or leak that activates the float switch. I unplugged the switch and now replaced the switch and it still keeps pumping. Even throughout a program it keeps running.
What can I test or check next ?
Thank you for help
