kelgun
#1 Posted : Thursday, December 7, 2023 2:53:34 PM(UTC)
kelgun
Hello all,
I have a Whirlpool LTE6234DQ2 washer/dryer that won't spin during the washer spin cycle. I had just replaced the motor coupler because it had broken. I also replaced the neutral drain kit in the transmission due to a broken part and replaced the water pump as a precaution. Any ideas on what may be causing the tub not to spin during the spin cycle? It appears to agitate fine during the wash.
Thanks!
kelgun
#2 Posted : Wednesday, December 13, 2023 7:04:17 AM(UTC)
kelgun
Bump....
