Guest
#1 Posted : Monday, November 20, 2023 6:27:14 PM(UTC)
Guest
Rank: Guest
Groups: Guests
United States
I have everything ready to go , unfortunately when it came time to take the part off the transmission it is stuck. I cannot remove it at all. I did try wd 40, unfortunately that did not work either. Thank you
sears/kenmore motor coupling replacement (Washer Repair)
by ron_gedye 3/23/2011 11:17:29 AM(UTC)
coupling replacement / rubber gasket found (Washer Repair)
by a1putt 6/18/2010 7:01:27 AM(UTC)
kenmore 60 series not spinning after motor coupling replacement (Washer Repair)
by orion359 3/29/2010 3:56:34 PM(UTC)
Motor Coupling replacement (Washer Repair)
by ErinK 4/14/2009 2:15:11 PM(UTC)
