Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I purchased a Walmart coffee maker 2nd hand store and it's filthy (think it's called Mainstay although no name on it) #8H45E207383. Cleaned it numerous times with vinegar and water and stopped perking. Put baking soda in- nothing. Think coffee grounds in water area has blocked tube. Not sure how to get bottom off to check tube. Would send picture if I could. I can't see where the coffee maker bottom, part or whole, is cut to come off. How do I get bottom off to check tube and hopefully clean without taking it out of machine.. Tube runs up center of machine and cannot take it off and get back on as far as I can tell without taking bottom off machine. If I can't get the bottom off, how do I clean out tube. All suggestions welcome please.
