Hello, I have a 2 year old GE water softener (GXSHC40N) that fills up with water and doesn't drain if I run a regeneration cycle. I've watched various youtube vidoes on it here's what I've tried so far: Took apart the nozzle and venturi assembly and thoroughly cleaned. Checked drain pathway, no clogs. Replaced brinewell (I cracked it checking salt for a clog). Replaced high flow valve rotor and seal kit. I've emptied the water from it several times and it will always fill back up over a few days time. I'm not sure what to try next and don't want to keep throwing parts at it if I don't know they're going to fix it, but would prefer not to replace it if it can be fixed since it isn't that old. I've also checked with the 2 appliance service providers in my area hoping one of them could come out and repair it but neither of them work on water softeners. Any ideas/suggestions would be greatly appreciated! Thanks in advance!! Edited by user Thursday, November 9, 2023 5:46:30 AM(UTC)
| Reason: Not specified
