My MLE2000AYW washer makes an awful noise in the spin cycle. Looks like I may need a lip seal kit and bearings. I found the lip seal kit here (AP4009088) and in its description it says "The rear bearings are sold separately. Their part numbers are WP22003441 and WP22002934."
Problem is that when I follow the links to these bearings and check model compatibility it says they aren't compatible with the MLE2000AYW. What can I do?
I guess I need confirmation of what causes this noise and what parts I need to fix it. Thanks!
