Freezer not cooling, refrigerator and ice machine working and making ice. Freezer will not get below 46 deg F. Replaced the temp sensor in freezer since it was a quick and cheap part. That did not help. I cleaned the condenser coil. It was not really that dirty to begin with. The condenser fan is running and so is the evaporator fan in the freezer. I shut it off for a day to defrost the ice maker. When I plugged it back in the refrigerator got to temp and it did start making ice. Freezer just got to 46 deg. I cannot find any other info online about the next troubleshooting step. Any info would be appreciated.
