Hi:
I have a Kenmore 110.21252112 washing machine that most of the time will not finish the complete cycle. The machine stops sometimes at the rinse process and other times stop when the LED marks the spin cycle. Sometimes it will not rinse at all and the machine do not drain the water at all and I have to remove the clothes manually and empty the water in the machine by gravity. I replace the Lid Lock Latch and the Strike but it did not work. If I reset the machine and select the Spin/Dry position, the machine will continue until the cycle is complete. Any help on this problem? Thanks.
P.D. I did post this as a guest but now I am a registered user.
Hi: I checked the washing machine again and now it just wash the clothes but just stop after that. It won´t continue to the rinse cycle and beyond. I run the diagnostic test and it does not show any error code. Just the sensing led flashing. Any ideas to solve this problem? Edited by user Friday, August 18, 2023 11:43:03 AM(UTC)
| Reason: Not specified
Joined: 12/4/2022(UTC) Posts: 0 Was thanked: 1 time(s) in 1 post(s)
Hi
I does do the sensing, water going in, wash the clothes, and after that it just stop. I have to remove the clothes and rinse them manually.
Hi:
I remove the agitator and replace the agitator dogs that were broken. I place the machine in the Automatic Test Procedure and it will go thru all the test without a problem except for the Drain Pump Runs step. It will not start the drain pump. I tried the Manual Test Procedure and the Drain Pump did not run in that step either.I replaced the drain pump but still have the same problem. What should I check next? Need help, please.
