A few weeks ago, the fridge stopped dispensing water or making ice. Tracing the water flow, no water was making it beyond the filter. Replaced the filter, and it would not fill with water. Tried another filter, same thing, it would not fill with water. Verified water is getting up to the filter housing, with good pressure.
I ordered a replacement housing. Swapped it out, and same problem. Water gets to the filter, but the filter will not fill up and send water on to the ice maker / water dispenser.
I'm not sure what else to check and any help is appreciated.
