Our GE DPSE810EG6WT dryer stopped working suddenly and I found the the motor run relay was bad. Purchased new AP4980747 (WE04M10004) control board assembly. Dryer now runs but times on digital display seem to be longer than the last board. Moved all of the connectors including jumper block on connector J3. Has the programming changed? Edited by user Tuesday, July 11, 2023 5:05:04 AM(UTC)
| Reason: Not specified
