Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
We have had issues with the icemaker in our GE model GSE25ETHB WW. When it gets full to the brim with ice, I usually turn it off and let the ice bin empty some before turning it back on and refilling it. Twice now, when I turn it back on, it makes noises like it's trying to eject ice, but it won't. The last time, I turned the temperature up as far as it would let me, and eventually it loosened and started working again. Will it burn out the motor, leaving it to its attempts, or should I maybe put a hair dryer on it? Thanks in advance!
