Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Maytag MSD2456GE Side by Side fridge with ice/water dispenser. I previously posted on here about the LEDs of the fridge not working. LEDs in freezer work fine. Was told to pull main board below fridge and test 2 pins to see if 12V appeared when the door opened. It does which apparently means I have a broken wire somewhere. Door switch also tested and all LEDs tested in freezer and all work. Before I try to locate this broken wire, is there any suggestions as to where to look? Since a fridge doesn't move and I don't think the wires go through the door, where is a possible spot where a wire can just "break". When I was testing the main board I wiggled all wires and connectors to see if it was there but no luck under the fridge. Is there a weak link somewhere? Thanks Dave
