Joined: 6/11/2023(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: WA
My fridgidaire affinity washer is leaking from inside the machine. It had been leaking small amounts for some time from the front door. A few days ago my wife had water all over the floor and thought it came from the front door so I replaced the boot seal. After putting it back together it leaked water from out the bottom of the machine and not the front door. The only thing I can think of is that it's leaking from between the drum and the inner seal but idk. It does squeak quite a bit, assuming it's the new seal. Also, when I ran the rinse cycle to test it, the machine stuck on 6min spin for 20min and never progressed. I checked the tech manual that was taped to the inside and the only action for leaking water was "fix leak". Lol.
If anyone has any guidance or insight as to where else it could be leaking water I would appreciate it. Tia
