Thermador 272 double wall oven. Trying to replace temp sensor. Factory manual shows you pull out the wire and cut/splice it. In reality, I can't pull it out more than about 2-3 inches. Has anybody done this? Any way to remove the oven interior to get to it? Or do I need to take the whole oven out and work from behind? https://www.manualslib.c...C302.html?page=27#manual
