ksenger
#1 Posted : Thursday, February 21, 2008 1:15:40 PM(UTC)
ksenger
Was useing it one night and it just went dead. There is power to it i pulled the fuse out and check it for contunity and it was good. Any other ideas. According to the wiring diagram the hot goes from the fuse down to whats called a mgt thermostat and there is power comeing to that but nothing comeing out the set of 2 wires from the thermostat on. The display dosent light up or anything. So would that thermostat going bad cause the problem i am describing. the microwave is like a year and a half old.
