Pete Pliers
#1 Posted : Wednesday, April 19, 2023 4:41:06 PM(UTC)
Pete Pliers
I'm a beginner with appliance repair, so bear with me :)
The bottom section of the fridge stopped cooling a couple of days ago but the freezer was at normal temp. The freezer evaporator fan wasn't running, so I checked it as per the service manual and it is bad. I ordered a replacement and it should be here soon.
In the meantime, I replaced the evaporator fan panel without the dead fan mounted. The freezer eventually gets cold but the compressor won't stop running. After about 20-30 minutes it gets too warm to comfortably keep your hand on it (the compressor fan is working OK). I don't want to run the fridge at all if it might damage the compressor, but I don't know where to go from here :(
Could all this result just from the evaporator fan quitting?
Edited by user Wednesday, April 19, 2023 7:29:41 PM(UTC)  | Reason: Updated...
