Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
It has water supply, checked the Inlet valve coil, it had 34ohms. Can the Float Mounting Tube be the issue. The float moves freely. How does this unit operate, there aren’t any electrical connections to it? Can it be tested?
Thank You, G
